1994 Volvo 850 Fuel Pump Relay Location
Upcoming ES90: What to Know
warrior094
- Year and Model:
I viewed a previous response to locating the fuel pump relay, I found a #103 relay in the fuse box under the hood but it isn't red in color (it's green) and the part number didn't match the part number identified.
White850Turbo
- Year and Model:
The fuel pump relay can be found in the fuse block. You'll need to remove the 4 torx screws around the fusebox to access it.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
- 11 Replies
- 2173 Views
- 4480 Views
Last post by wizechatmgr
