no courtesy lights?
Change the Fuel Pump DIY, 2004 XC70
no courtesy lights?
I have just purchased a 1993, 850, good engine and transmission. Non of the courtesy lights work, doors, rear ash tray, dome lights (front or rear). Several bulbs were blown. Got new bulbs. All fuses are good. Any suggestions?
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
I assume you tried to put a meter on the wires to check for power, if not that would be the first thing that I would do.
Be aware that the dome lights will only come on if you set the switch for when the door/s are open. Regardless of the setting for the dome light, the red door lights will come on when the door/s are open. Your problems maybe as simple as broken wires, which you will need to trace.
Tailor
Tailor
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
If NONE of them are working, I might actually suspect the central lighting relay has blown. I believe it's the 2nd row up on the panel under the dash, it's relay "K".
'98 S70 T5
2016 Chevy Cruze Premier
