1997 855 Nautic Blue part out
cheapwagon
Year and Model:
Re: 1997 855 Nautic Blue part out
Post by cheapwagon »
rommel0915 wrote:Oil Filter with plenty of drain plug O-rings and oil cap O rings
How much more for these? I did not see that earlier.
$4.00.
Thanks for the payment.
I just wanted to explain my prices that was all.
I will have this in the mail tomorrow for you.
97 855 GLT somewhere around 214k
rommel0915
Year and Model: 1995 Yellow 850 T5R
Post by rommel0915 »
Payment sent and thanks.
1995 Volvo 850 T5R (Yellow)
1995 Volvo 850 Turbo
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
Hey cheap..do you know if the tracs, sunroof, and defrost switches still light up like they should with the headlight switch turned on ? if so, im needing all three.. let me know how much.. thanks..
1996 Platinum Edition
cheapwagon
Year and Model:
UPDATED PARTS LIST WITH PRICES
Turbo Downpipe with Catalytic converter and O2 sensors. $80.00
Complete set of Tail lights with Bulb Holders $80.00 or $50.00 for uppers and $30.00 for lowers. Almost mint condition with no hazing.
Complete Passenger Heated Power mirror in 417 Nautic Blue $25.00
Stock Airbox for SAS cars. $10.00
under Hood Cowl $10.00
Spark Plug cover $10.00
Speedometer Cluster reading 185k $15.00
Info Display and Switch $15.00
Knock Sensors $5.00
ECT engine coolant temp sensor $10.00
Wiper Motor $20.00
Starter $15.00
SAS Air Pump w/ relays and control valve. $50.00
1997 GLT ECU Bosch #936 $15.00
Aisan Transmission computer $15.00
Interior switches $2.00 each
Fuel Door release $10.00
Fuel Rail with Red Injectors $15.00
TD04HL 13g Turbo $30.00
Walbro Fuel Pump $35.00 Only 15k on pump
Intake $15.00
EVAP Purge Valve $25.00 Only 12k on Purge Valve
Turbo Hose for IAC/Throttle body. $10.00 only 5k on hose.
Idle Air Control IAC $20.00 Recently cleaned
IAC top hose $3.00
Boost Control Solenoid $10.00
Turn Signal Stalk $5.00
Wiper Stalk $5.00
Throttle Body $5.00
Coin tray $5.00
Intercooler hard pipes $10.00
Headlight wiper trims $10.00
Vacuum Tree $5.00 Almost brand new
New in Package 1994-1997 Volvo 850 Turbo Rear Trailing Arm Bushing Kit-Left Side $30.00 http://tinyurl.com/2btjfuf
New in Package 1994-1997 Volvo 850 Turbo Turbo Cooling Hose-Outlet $4.00 http://tinyurl.com/26eyluf
15" Steelies with tires. Tires are old but have a lot of tread depth. One Michelin , one BF Goodridge Traction T/a $$$offer and local pickup
I may have left some things out but this should be just about it. Let me know if you have any questions and offers are welcome.
phils94850
sent you a pm about the switches...
cheapwagon
Year and Model:
I need this stuff gone.
rommel0915
IAC top hose $3.00
How much for all these? I probably should have waited. : )
turbosnow
Year and Model: 1994 850 Turbo
Post by turbosnow »
I'm interested in the downpipe/cat, how much would you charge to ship it to 13066?
Thanks
rommel0915
I just sent you a pm about the headlight.
cheapwagon
Year and Model:
rommel0915 wrote:I just sent you a pm about the headlight.
I just replied. Let me know what you want to do.
