Driving wives car today to troubleshoot some items. I never heard this sound with any car I've owned. Often (not always) when letting off the brake from a dead stop there is a sound from the floor like a vacuum release. It can run on for 20-30 sec after driving away but seems most pressurized from the initial release.
What is unique to this setup, or what is should I be concerned about?
air sound when often (not always) releasing brake?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
you have a vacuum leak at the brake booster.
You'll need to replace the brake booster to fix it, another common failure in '01-'02's. Do it sooner than later or one day, when you really need it, you'll end up with no power break assist.
Thanks. Will research it now. I'm actually amazed at how good the brakes are on this car, but I've never done a power booster in all my hears. Is it easy to get to on this car? I'm amazed at how much I hear the noise in the foot area rather then on the outside firewall.
EDIT: HOLY S$%^%T...$500 for one with DSTC! Not good...
How can it be common to all models if some have DSTC other have STC and some (Base?) have none? Shouldn't these boosters be different designs if they are different model numbers and not interchangeable?
What is serviceable in them? I know some simply have check valves go bad.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
You're in luck, the '01 does not have DSTC but plain STC, the booster is much cheaper.
A new ATE (OEM) booster at FCP groton with the 10% off coupon comes to about $200. When you are ready to change it, post back and I'll give you a few tips. I did mine a couple of months ago.
My research says it can be done just fine in place, just a bit tedious from what I can see. We checked the boot on the inside of the drivers compartment, placed it back over the seal and the sound has gone away, found a post on this topic but don't have it handy right now. So I am still monitoring this to determine if there is really the concern.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
gchardy,
this is a DIY job, that can be done on a Sat morning. The worst part is removing the 4 nuts that hold the booster under the dash board. You need to lay on your back to get to them.
-you do not need to disconnect the ABS hydraulic lines,
-do remove the hard plastic intake tube to the turbo
Post a new thread when you are ready to tackle this job, and I'll give you a few more tips.
