DIY: 1998 Volvo V70 Instrument Cluster Removal/Bulb Change
johnnchrisr
- Year and Model: 98S70, 01C70, 05XC90
My bad - I see the picture of the harness as removed. Maybe I should have looked a little more closely
1998 S70 Base, Silver, 143k
2001 C70-C LT, Silver, 140k
2005 XC90 2.5T AWD, Burgundy, 112k
thecheat
- Year and Model: 1996 850 Turbo Wagon
Re: the oil mist behind the lens... maybe it is traveling up the vacuum tube for the boost gauge?
Also - anyone wanting to shortcut and not remove the dash completely.... well, you CAN do it that way but it is probably twice as difficult to do. Remove the dash entirely and you won't run the risk of breaking things. I learned my lesson and when I go to replace the OTHER odometer gear - which was also bad, I will remove the dash.
JFO
- Year and Model: '98 S70 GLT
Before you start, make a note of the location for the annoying service light and remove the bulb while you have it apart. I planned to do this when I did the evaporator and then forgot about it.
Jim
Jim
'98 S70 Turbo GLT
280,000 km
280,000 km
- Been thanked: 504 times
JFO,JFO wrote:Before you start, make a note of the location for the annoying service light and remove the bulb while you have it apart. I planned to do this when I did the evaporator and then forgot about it.
Jim
Funny you said that because when I did this job I did not think about the Service Reminder Light because during the last 10 years, I placed a small piece of black electrical tape over the annoying Service Reminder Light!
v70xc
- Year and Model: V70XC AWD Turbo 1998
CN90... any chance that you could possibly give me direction since you have obviously taken out the cluster. I have a film of oil on the inside of the console lens?
In short, if I remove the dash and the cluster, will I be able to remove the front lense?
I need to get to the inside of the lens to give it a good cleaning.
Is this possible once the cluster is removed?
Hope I don't have to break a glued tight seal.
Thought????
thanks
Thought????
thanks
1998 V70XC AWD Turbo
I have no idea how to disassemble the cluster lens.v70xc wrote:CN90... any chance that you could possibly give me direction since you have obviously taken out the cluster. I have a film of oil on the inside of the console lens?
Why don't you remove the cluster, then see if you separate the 2 halves?
nicopag
- Year and Model: v70 2.5T, 1999
But there is a simply procedure tu turn it off. I did it yestarday and works great on my Volvo V70 1999cn90 wrote:JFO,JFO wrote:Before you start, make a note of the location for the annoying service light and remove the bulb while you have it apart. I planned to do this when I did the evaporator and then forgot about it.
Jim
V70 2.5T, L.H.D /S.R, 1999
- 5047 Views
Last post by oragex
- 11 Replies
- 4385 Views
Last post by Faheyk1981
- 15 Replies
- 2492 Views
Last post by volvolugnut
- 732 Views
Last post by shaker_chi
- 1279 Views
Last post by oragex
