DIY: 1998 Volvo V70 Instrument Cluster Removal/Bulb Change
This topic is in the MVS Volvo Repair Database » 1998 Volvo V70 Instrument Cluster Removal/Bulb Change
johnnchrisr
Year and Model: 98S70, 01C70, 05XC90
Post by johnnchrisr »
My bad - I see the picture of the harness as removed. Maybe I should have looked a little more closely ;)
1998 S70 Base, Silver, 143k
2001 C70-C LT, Silver, 140k
2005 XC90 2.5T AWD, Burgundy, 112k
thecheat
Year and Model: 1996 850 Turbo Wagon
Post by thecheat »
Re: the oil mist behind the lens... maybe it is traveling up the vacuum tube for the boost gauge?
Also - anyone wanting to shortcut and not remove the dash completely.... well, you CAN do it that way but it is probably twice as difficult to do. Remove the dash entirely and you won't run the risk of breaking things. I learned my lesson and when I go to replace the OTHER odometer gear - which was also bad, I will remove the dash.
JFO
Year and Model: '98 S70 GLT
Post by JFO »
Before you start, make a note of the location for the annoying service light and remove the bulb while you have it apart. I planned to do this when I did the evaporator and then forgot about it.
Jim
'98 S70 Turbo GLT
280,000 km
Been thanked: 504 times
Post by cn90 »
JFO wrote:Before you start, make a note of the location for the annoying service light and remove the bulb while you have it apart. I planned to do this when I did the evaporator and then forgot about it.
Jim
JFO,
Funny you said that because when I did this job I did not think about the Service Reminder Light because during the last 10 years, I placed a small piece of black electrical tape over the annoying Service Reminder Light!
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
And if you don't want to do this ever again...
http://www.autolumination.com
LED's are a good thing. 8)
Post by cn90 »
Actually from my research, some like LED some don't (and switch back to OEM bulbs).
Personally, I like the OEM bulbs.
BEJinFbk
Post by BEJinFbk »
Good point. Any thoughts out there?
v70xc
Year and Model: V70XC AWD Turbo 1998
Post by v70xc »
CN90... any chance that you could possibly give me direction since you have obviously taken out the cluster. I have a film of oil on the inside of the console lens?
In short, if I remove the dash and the cluster, will I be able to remove the front lense?
I need to get to the inside of the lens to give it a good cleaning.
Is this possible once the cluster is removed?
Hope I don't have to break a glued tight seal.
Thought????
thanks
1998 V70XC AWD Turbo
Post by cn90 »
v70xc wrote:CN90... any chance that you could possibly give me direction since you have obviously taken out the cluster. I have a film of oil on the inside of the console lens?
I have no idea how to disassemble the cluster lens.
Why don't you remove the cluster, then see if you separate the 2 halves?
nicopag
Year and Model: v70 2.5T, 1999
Post by nicopag »
Jim
JFO,
But there is a simply procedure tu turn it off. I did it yestarday and works great on my Volvo V70 1999
V70 2.5T, L.H.D /S.R, 1999
