So i then cleaned up the maf sensor bits and pieces, along with the air idle control valve. Still no improvement.
Out of desparation i removed the distributor cap (which along with the rotor is also new) and lo and behold-lots of moisture inside. A good wipe-out, a shot of WD40, another wipe to remove the excess, cap back on, and WHOOSH! She ran like a dream.
I also noted that i seem to be leaking a very small amount of oil from where the distributor meets the cylinder head.
Spoke to a volvo main dealer in the area, he said there is a rubber o-ring type thingy between the camshaft and the distributor, which the rotor passes through, so i've ordered one of those to collect tommorow.
I'm just left wondering why i had so much damp in the distributor cap, can anybody shed any light on this please?
