what is tranny fliud
Power Steering Noise At Low Speed 2004 V70
JRL
- Year and Model: Several
- Been thanked: 16 times
What do you mean by "what is tranny fluid"?
JDS60R
- Been thanked: 3 times
It is the fluid in the transmission. It cools and lubricates the unit. You should have a professional change it so that the proper fluid and technique are used.
I would suggest a Volvo dealer or Volvo specialty shop as some shops who do not know Volvo's may use the wrong fluid or try to fill it back up in the wrong spot causing damage.
Some people refer to it as a gearbox or an automatic gearbox. Your owners manual will give you the proper fluid recommendation.
Your owners manual is always visible at www.Volvocars.com
look under "Community" and then type in the document you want in the search boxes
Retired
JRL
Allow me to say something
if you needed to ask this question, you really have no right to start modding and asking which size exhaust to buy.
UNDERSTAND YOUR AUTOMOBILE, how things work and what does what.
I read on a the web they say if you put toyota iv oil and flush it
3times and flush the B4 servo I don't know what that is !!!
Okay they say it will be fine
My qestion is what grade toyota oil I must use
And what is a B4servo
My automatic gearbox clicks when I put it in reverse and when I drive and slow down it gears down smoothly
But when I don't stop dead and exalerate it clicks like it wasn't the hole time in gear!!!
JRL
what you read is you DRAIN AND FILL it (not flush it) 3 times.
I would not worry about the B4 servo just yet.
That is a small part that can effect the 3-4 UPshift, you change it, don't flush it.
From what you said, that doesn't seem to be your problem
RaymanSean
- Year and Model: V70 XC, 2001
You need at minimum new torque mounts or bushings and more likely the torque mounts and the pasenger's side motor mount.jannie 1 wrote: My automatic gearbox clicks when I put it in reverse and when I drive and slow down it gears down smoothly
With all your questions , maybe you could get a manual, and find a VERY good Volvo shop..Do you know how a engine works?
.2003, V-70,. 2.4T, 101,100K..
.1985, 245T,.sold at 280K....
.1974, 145, sold at 250K....
cdnbluez
- Year and Model: 09 C30/98 V70/99 S70
If you're buying transmission fluid, whatever brand, make sure it's 3309. In your case I'd recommend taking your car to a reputable Volvo shop, they'll know what to use. I don't hink a flush, or a drop and fill will solve your issues, they sound more serious.
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
2005 S40
2006 XC70
2014 Mercedes E350
- 16 Replies
- 2245 Views
Last post by 850TurboTurtle
- 622 Views
Last post by sacricide
