How do I find 240 fault codes?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
marknsea
Year and Model:
Post by marknsea »
I've got a 1990 240DL wagon. The "check engine" light stays on and I want to know the fault code for my problem. How do I find this code?
Thanks
Guest
Post by Guest »
On the drivers side inner fender there is a small box with a wire with a small metal plug on it. You open the box and there is a particular routine that you go through. I do not have this procedure with me at this time. Do a search and see if you can find the procedure and the codes. Do not guess at it.
