XC90 2008 replace brake light harness
Is this easy to replace? Got water in the light and it corroded. Ordered harness and lens from volvo but dont want to run into any issues. Seems like to harness is in the inside compartment where you unscrew the len but is it easy to get at? thanks for the help
should be, probably just depends on how far back you have to go to get the the next connector for the harness. The lens (if you are talking about the exterior housing) is super easy to replace, two bolts, I have a post somewhere back that has a PDF on how to remove those.
05 V70R TiKap (so happy) 91K
05 XC90 2.5T FWD TiBlak 97K
94 850 wagon 2.4 (N/A) 155K (Sold running like a champ)
- 14 Replies
- 3920 Views
Last post by CIK7
- 3417 Views
Last post by bethanyXC90
