help for high pitch noise
volvovera
Year and Model: 04 S60 T5
Post by volvovera »
Could any one give me some suggestion to diagnose this high pitch noise issue please?
The noise coming from the rear end whenever I start the car. The noise is not loud and does not change when the car is under acceleration and at idle.
With a kind former suggestion from this forum, I had my car checked in a dealership. The mechanic only opened the fuel filler door and put his ear against fuel filler cap and then told me that the noise does not come from fuel pump. He said it was an exhaust noise which is normal.
My question is that whether the fuel pump noise can be so easily excluded without any other check? :?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Do you hear the noise if you flip the key to position II without starting the engine?
'98 S70 T5
2016 Chevy Cruze Premier
volvovera
Post by volvovera »
When I turned the key to the position II, there is no high pitch noise.
Also I tried to put my ear against the gas cap after I started the engine and opened the fuel filler door, the high pitch noise does not come from inside fuel tank.
FCPEURO
Year and Model: 2006 XC90 V8
Post by FCPEURO »
Try putting your ear to the back seat and see if you hear it coming from there. It sounds like a fuel pump to me also.
volvovera
Post by volvovera »
Thank you for your tips FCPGroton.
As you suggestied, I put my ear against the right side rear seat, and can not hear any noise
Then I put my ear against the part which is leg area under the right side rear seat, also can not hear any noise (sorry for this pooor description)
This time I opened the gas cap, and I can hear a tiny high pitch noise by which means the sound is not as loud as I can hear around the car.
