Greenies look away now. The amount of kludge, sludge and general junk that my motors have to eat from the PCV bothers me. I'm considering blocking the holes at the PTC ant whatnot and venting it. Actually the V70 is venting now anyway due to a broken pipe.
Thoughts?
Anyone Considered Venting their PCV System
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
One consideration for you: those crankcase fumes smell like sh*t when you're idling and the fan is pulling them into the car. I can't stand it.
'98 S70 T5
2016 Chevy Cruze Premier
boosted5cyl
Yeah I noticed that when the S80 had a cracked breather box. I guess if I could redirect it under the body of the car it mightn't be as bad. Worrying thing is I'm not getting the smell in the V70 even though Its not connected because I broke the pipe at the PTC valve over the weekend, probably clogged. Booooojablackburn wrote:One consideration for you: those fumes smell like sh*t when you're idling and the fan is pulling them into the car. I can't stand it.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I feel that this is a topic affecting the full range of cars.Should'nt this thread be in the S70/V70 section?
In the 1960s, when I started to drive, crankcase gases were vented to the atmosphere. It wasn't unusual to be following a car with bad rings blowing so much out of the vent that visibility was reduced. The smell, in some cases, was overpowering. Do we really want to go back this far?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
I got a new elbow for my pcv vacuum line where it goes into the manifold....is it safe to cut off the bad elbow and super glue the new elbow to the existing vacuum line and put a small clamp where in connects at the manifold so it doesn't pop off...Is that the best way to fix it with superglue???
jblackburn
Nois it even legal to vent the gases into atmosphere?
Go for it. PVC pipe cement also works well for gluing things like this together. Otherwise the elbow often falls off, and the small line there is a pain to fish back up again.I got a new elbow for my pcv vacuum line where it goes into the manifold....is it safe to cut off the bad elbow and super glue the new elbow to the existing vacuum line and put a small clamp where in connects at the manifold so it doesn't pop off...Is that the best way to fix it with superglue???
'98 S70 T5
boosted5cyl
No idea. Theres no emission testing\requirements in MN.charlyW wrote:is it even legal to vent the gases into atmosphere?
