dbgt202
dbgt202
Year and Model:
dbgt202
Post by dbgt202 »
I have a problem with my 94 850. For the past couple of months my car has had a starting problem. Once in a while when i try to start it, it wont start. Some times im filling up gas and then i try to start it doesnt. I wait a few minutes and then it starts right up. ITs been doing that like i said for a few months and today my dad moved if from infront of the mailbox to the driveway this morning and started right up. This afternoon i tried starting it to pick up my mom but it didnt start. This was around 1230 its no minutes to 8 and it still wont start.
does anybody know what could be a problem?
I am getting the code 232, and i also have a bad pnp switch..
Could those be the problem?
dosbricks
Post by dosbricks »
Which socket are you pulling 232 from? It can mean different things depending on if it is the A1 or A3 socket.
Try ratcheting the shift lever back and forth through all the gears about ten times. Sometimes it will knock some corrosion off the PNP contacts and get you started.
White850Turbo
Year and Model:
Post by White850Turbo »
Sounds as if it could be a problematic fuel pump relay as well.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
