dirty rims
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Re: dirty rims
Post by tjts1 »
Clean it, sand it, prime it, paint it. No point in trying to save 15 year old wheel paint.
Ambitious but rubbish
Allen in Hemet
Year and Model: 2000 V70XC SE
Post by Allen in Hemet »
Then, after you have cleaned and/or repainted the rims, and after the brake pads have worn down, replace the front brake pads with Cereamic pads. Available on line at Carparts.com, partstrain.com, and your local Autozone store also have them. Ceramic pads don't create black dust and have very good braking characteristics. R/ Allen
mindshadow
Year and Model: none
Post by mindshadow »
Get some P21s (gel if you need some extra cutting power). It absolutely won't damage your wheels and it cut through brake dust that I was certain nothing would remove. Looking at the photo of your wheels, that's nothing compared to how mine looked before. Now they look brand new. Use the Matthews Amazon link up top and search for P21s so the site gets the referral link. :)
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
Not too sure the stuff I use will be available in the USA, I use a trigger bottle made by "Astonish" its just labeled up as Alloy Wheel cleaner, costs under £1 and works great, spray on, agitate with a soft brush then rinse with water, under £1 and you get enough to clean all four wheels at least eight times each - Mike
cdnbluez
Year and Model: 09 C30/98 V70/99 S70
Been thanked: 3 times
Post by cdnbluez »
OK, so I just picked up a set of Columba's today. They are from a '95 850 and are pretty dirty. Came with decent tires, $200. I bought some Greased Lightning, it worked pretty good. The caked on black spots are hard to remove. It will take a few tries. It was getting cold so I gave up. Here are the results
Mounted on a dirty car! They'll be coming off before it snows again.
Most of the brown stuff came off, but the black dry tar-like stuff is hard to remove. I left one area untouched.
Couldn't resist, had to post  pic after car wash.
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
gilhuly
Year and Model: 98 V70 GLT
Post by gilhuly »
Easy off over cleaner, yellow can
1998 V70 GLT, 15G swap
Fairfield, CT
thecheat
Year and Model: 1996 850 Turbo Wagon
Post by thecheat »
That wheel doesn't look TOO bad... buy wheel cleaner with acid in it (look on the bottle, most say there is only a surfactant in it but you want the acid) and spray it on, wait 30 seconds, then rinse it. Don't leave it on and especially make sure it doesn't stay on the rubber as it can whiten it.
If you use it sparingly it won't cause too much damage to the paint.
