electronic rustproofing - is it worth it?
Guest
Post by Guest »
I read about this in a mag today.
http://www.ruststop.com.au
An electronic device helps prevent rust and inhibits exhisting rust. It is called RS 2000.
It is $195 do it yourself or $340 installed (Australian $)
What do others think?
Is it a good idea for a 1996 Volvo owner wanting another 10 years or are these cars rustproof enough as they are?
Independent tests show it inhibits 76% of rust, or so they claim.
Jot
Year and Model: C30 2010
Post by Jot »
After reading the web site you can get the same results for a lot less money. Boat motors have anodes attached to prevent rust.The anodes can be purchased at a boat dealer aand then bolted to any bare metal.
Guest
Post by Guest »
Before you spend your money go to the following and see why there is no way it could work unless the car is underwater.
http://www.corrosion-doctors.org/Car/ca ... c-rust.htm
