problem reversing
Notes on Changing the Timing Belt
evegreen
- Year and Model: 1999 V70 XC 2.4L
problem reversing
'99 V70 XC turbo 157,000 is having problems reversing, feels like it is in neutral when I try to rverse.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Usually not a good sign - I would start by changing the transmission fluid.
https://www.matthewsvolvosite.com/2006/1 ... sh-method/
'98 S70 T5
2016 Chevy Cruze Premier
JRL
- Year and Model: Several
- Been thanked: 16 times
Just had a car with the same issue, the tranny was totally shot internally.
Evntually the shifting issue will travel to the forward gears
evegreen
After just replacing the alternator and catalytic convertor to the tune of $2000 and lots of work such as PCV breather box, front struts and much more is it worth replacing the transmission when I can't do this type of work myself? I am in a quandry.
JRL
Erie
Used tranny w/guarantee between $600-$800
You should be able to find someone to install it for $800
Unfortunately this is your best proposition.
You may as well go this route if you like your car, otherwise you will have wasted all that money you just spent
