'99 S80 T6 Top End Rebuild Pics
How to Rebuild the Head on a S80 T6
mrjacobrussell
- Year and Model: 2006 s60R
- Has thanked: 2 times
I used the cam lock tool scored on ebay fof only $ 240. Rubber mallet to persuade it down. Clamped it down the persuade some more
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
I actually eyeballed the cam timing, I'm getting good at it now
mlanctot
- Year and Model: 1999 S80T6
Awesome write up! My 99 S80T6 just died. Lost compression on two cylinders. Zero compression, so I figure valve problem. I'm a back yard type mechanic. Can this job be tackled by the likes of this poor sole? Is there a direct write up of what is required? What would a job like this cost if it is sent to a shop?
boosted5cyl
Not sure to be honest. I paid about $160 to get the head pressure tested, cleaned and surfaced. The rest was DIY. I would say $1500 would be on the cheap side for a shop. Lot of stuff to disconnect before the head comes off.
JDS60R
- Been thanked: 3 times
Check out http://www.cylinder-heads.com
You will have the head when you are taking your old one off so you can reassemble the day you take it apart. The cams will be align bored and the work is done by specialists.
Retired
mlanctot
Well the Head is off. Like in the pics mine has a lot of carbon build up. Nothing noticeable visibly. Now I have to decide to speed money on the block or finish taking out the old engine and replace it with the used one. Hmmm
mlanctot
Well, I have 2 exhaust valves that are bad in different cylinders. I'll get a quote on this and decide to either put in the used engine or just rebuild the Head. Anybody have anything to say about Clearwater Cylinder Head Inc. I can get a rebuilt head from them for $450. I'm more familiar with shops here in CT.
How did you get the engine block so clean??
