Mangefine Filter Installed w/ Pictures
This topic is in the MVS Volvo Repair Database » Mangefine Filter Installation Tutorial w/ Pictures
velorider
Year and Model: 2005 S60 T5
Has thanked: 2 times
Been thanked: 27 times
Post by velorider »
Today I finally got around to doing the transmission flush on my wife s60. The car had 94K miles on it and I'm not sure it's ever been done, so I was a little worried about the urban legends of high mileage flushes. Legend goes that the new fluid loosen "stuff" and could cause issues with the transmission. I've also heard the S60 does not have a transmission filter.
So to provide a little piece of mind I installed a Magnefine filter, http://www.emergingent.com/subpage1Magnefine.htm. I've install one before on my Ranger, but the wiggle room difference between the Ranger and Volvo is enormous.
Here are the steps to install the filter along with some pictures. I was very nervous cutting a hose that should cost $10, but Volvo charges over $100. I was not even sure I was going to be able to get the filter installed without kinks in the hose.
Installation Steps:
1. Remove the transmission cooler return line from the radiator. The one with the green clip on the top/driver side of the radiator.
2. Cut the hose about 1.25" from the metal fittings. You need about an 1.25" to insert the top side of the filter into.
3. Rather then shorten the hose I decided to just reroute the hose under the near by transmission inlet hose to give it more length and better fluidity at the bends. See the picture for the hose to reroute under.
3. Attach the filter to upper hose first, as this can be done completely outside to the engine making it easier.
4. Now with the lower hose rerouted install the filter into the lower hose. It's a little difficult but eventually got it pressed in. Took about 5 minutes.
5. Make sure the upper hose fitting is positioned to nicely go back into the radiator without having to twist it. If you need to twist it just spin hose at the filter. There is no need to introduce extra tension in the hose.
6. Reconnect the hose to the radiator.
Doug S
Year and Model:
Post by Doug S »
Thanks velorider, I always appreciate it when people take a few pictures and share them. I've considered an inline filter for the transmission in my 2001 V70 since it's such an expensive replacement item (replaced not long ago) and the filter seems like it would offer extra protection and at a low cost.
rbodor3
Year and Model: 01 S60 LPT
Post by rbodor3 »
Pretty decent job, did you add extra fluid to compensate for the bottleneck and extra for the filter? I assume not very much. FYI for future DIYers you can get the tranny filter at ipdusa.com.
01 Volvo S60 2.4T
VolvoS40S60
Year and Model: S40-2003/S60-2001
Post by VolvoS40S60 »
:?: I always wanted to do this on my wife's 2001 S60... I just did a drain & fill a month ago. The car still runs great at 102,000 miles... What size filter did you use ? Was it 3/8, 5/16 or 1/2 inch? Your help is greatly appreciated. Thanks!
velorider
Post by velorider »
I installed the 3/8 size. I've seen other post around saying it 5/16. I measured the I.D after I cut the hose and it looked more 3/8 then 5/16. 3/8 is a tight fit, 5/16 would be an easier fit. Truthfully I don't think the 1/16 will make any different.
Something I forgot to mention in the original post is I removed the air duct to the air box to give me more room to work. This is the black plastic duct running from on top of the radiator to the bottom of the air box. Removal is easy, no bolts to remove. The directions below make it sound more difficult then it is.
1. The duck flattens where it goes over the radiator. Wiggle it a little and you can see it move through a hole in the metal just in front of the radiator.
2. Looking through the hole you can see it snaps over a knob. Using a screw driver slide it over the knob.
3. Once the front is removed the side connected to the air box, just slides out.
I'll edit this tonight and post some pictures of the removal process.
igel513
Year and Model: 2003 S60 T5
Post by igel513 »
Is that a canister type filter or just a plain throw away filter like those used for motor oil?
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Thanks for the writeup! I keep my 2000 XC's fluid very fresh, although it's had a minor bit of a rocky past with some overdue fluid. I've really been wanting to add this filter, but I'm wondering if at 140,000 miles it's even worth doing now.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
marginal
Year and Model: V70 D5 2003
Post by marginal »
igel513 wrote:Is that a canister type filter or just a plain throw away filter like those used for motor oil?
It's a sealed throw away filter.
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
just installed one in my V70, thanks for the pictures
Howard_Woodard
Year and Model: 2009 XC90 V8 AWD
Post by Howard_Woodard »
@jda2000: What size did you use? 3/8 or 5/16?
Howard Woodard
Redmond, WA 98053
2002 Volvo V70 XC AWD w/2.4L Turbo (Chassis #058794)
