Hi, my antenna does not go down all the time, sometimes I have to manually push it a bit for it to go down. It also makes a strange grinding like noise when trying to go up or down. How could I fix this, would I have to get a new antenna?
Thanks.
Antenna problems?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
Step one - Lube It.
Fold a paper towel around it while it's up.
Spray some lube on it and wipe thoroughly top to bottom.
Try to leave a good coat on it so it spreads around well when
it you run it up and down a few times and it "does it's thing".
Point that can into the segment ends when it's going down
to get some lube down inside the reast of the mast.
I'd start there and see how much it helps.
or not...
But that will usually solve basic problems.
or not...
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
If that doesn't work, likely you've stripped the teeth.
There are two plastic parts, a normal gear and a straight toothed strip; if you're lucky, it's the straight piece that's stripped. That would come with a new mast, but you should open the assembly to find out before ordering. It's just as likely the round gear stripped, in which case, you'll need to replace the whole assembly.
5 others that came and went
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Good news is a new mast is super cheap! I think mine was $20 when I ordered a few years ago.
Keeping it lubed up is a twice-yearly thing that you really should do but most people forget about. When mine starts making weird noises, I always say "hey, that's something I need to remember to do more often!" and then forget again.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
There's a nut at the top of the boot where it pops out of the trunk - loosen that, pull out the old mast. Take note of the direction the toothy strip faces. Now feed in the strip for the new one while you have someone else turn off the power for the radio to run the motor, and hopefully it will catch in a few tries and suck it right in.
Make sure there isn't anything missing from the end of the strip when you get the old mast out - then you will have to access the motor and pull part of the old toothy strip out like the end of this topic:
https://www.matthewsvolvosite.com/forums ... =1&t=29818
'98 S70 T5
Schmitty
- Year and Model: 1995 Volvo 850 turbo
My antennae has never gone down (is permanently in the up position). Will this cause any problems for any other part of the car? I don't give a hoot, let alone two hoots if the antennae goes up/down but am curious if it's malfunction will effect any other systems.
1995 850 Turbo -- 118K miles
91 Octane Premium + 3oz. Lucas Oil
Synthetic Mobil1 5W30
K&N Air Filter
K&N Air Filter
jblackburn
Won't hurt anything - I forgot about mine and went through a car wash and bent it in half
'98 S70 T5
