ABS unit remove and test - new (or used) screws needed
avdberg2
Year and Model: V70 Estate V70
Post by avdberg2 »
Hi All,
Just a question about ABS unit repair. Finally a removed the unit from y car....bolds are rounded...and appearently trown away...so i don't have the bolds anymore...so question one is:
I just soldered the broken powersupply connector...but now a need the screws to put it back into my car
- Does anyone know the size related to this 4 screws ?? ...mm x ...mm
Is it possible to test the unit without screw it back to the car...so i know that it's working...
REGARDS,
aRJAN
Reason: Edited title - lower-cased the letters.
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
those are E5 torx screws. Why would you throw them away? I guess you could use other screws to hold the unit.
avdberg2
Post by avdberg2 »
screws where rounded...so can't be used anymore, does anyone know the size ..mm x ..mm
jimmy57
Been thanked: 320 times
Post by jimmy57 »
solder EVERY pin on the connector area. Some of those are almost guaranteed to be broken or will be soon.
