SAS delete and engine swap
Has thanked: 293 times
Been thanked: 765 times
I am swapping in an engine. The junkyard said it was from a car with an air pump but there is no SAS on the exhaust manifold.
Donor car: 98 S70, no SAS.
My car: 96 850, has SAS and air pump.
1.) Can I do this by simply carrying out the SAS delete procedure at the ECU, then eliminate air pump and related hardware?
2.) There is a lot of chatter on here for the S70 delete procedure; does anyone know for sure what needs to be done on the 850?
TIA
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
OK the definitive post over at VS that everyone is basing their SAS delete on, is for Motronic 4.4:
http://volvospeed.com/vs_forum/topic/14 ... with-pics/
And the combo of this page:
https://www.matthewsvolvosite.com/2010/0 ... n-numbers/
paired up with this VIN:
says that my car has Motronic 4.4
So SAS delete should work fine, right? Maybe I'll try the delete before I swap in the engine.
'06 S60 R, 197k
Did the SAS delete a week ago, no codes yet. Will start the engine swap this weekend.
'06 S60 R, 197k
