Hello! The washer fluid pump is working, we can hear it but no washer fluid coming out.
Please help. Thanks.
08 XC90 window washer fluid not pumping
jimmy57
- Been thanked: 320 times
volvo uses check valves to assure the water is dispensed immediately (not all when these clog...) due to lines staying full and not draining back into tank through pump.
The check valve uses where the line to hood splits for the two nozzles is prone to clogging with dried washer solvent.
They usually have to be replaced. Take the line single line off the check valve and then try the washer pump to see that it is coming out there. IF so get a check valve.
- 4941 Views
Last post by vajdaviktor
- 36 Replies
- 21742 Views
Last post by StickyPocket
