S60R Shifter failure? (manual trans)
S Booch
Year and Model: S60R, 2004
Post by S Booch »
As I shifted from third to fourth today on my way to work the shift lever popped loose. The trans is stuck in third or fourth and the shift lever will only move front to back between third and fourth. I popped the cover off and looked around but I can't see much without removing the ball assembly and shift knob. It appears that most of the shifter mechanism and linkage is plastic - is this a common failure? The car has 109k miles. Any tips from the experts?
Thanks in advance
Steve B
2004 S60R
Past Volvos: 66 122S, 84 242T, 85 244T, 85 745T,
88 780, 95 855 T5-R, 96 854R
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Common?
So So. Some have, some haven't. If you have an 04, you need to buy the upgraded cables
I had one pop loose and I was dead in the water (I was under warranty at the time)
The Volvo tech made up a couple of small clips tapped into the case and bolted them to the tranny
Never a failure since
Oh they come off under the hood too
S Booch
Post by S Booch »
Thanks for the info JRL.
Steve B
2004 S60R
troma
Year and Model: 04 s60r
Post by troma »
I just had the same problem on my way home from work. how much was it to fix? thanks
