what are the AWD system changes by year?
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
I'm sure this is in a post somewhere...but I"m not hitting it.
A breakdown of viscous gen 1 vs gen 2, 3 ect...
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
There is no 3
98-02 Gen 1 VC
02 to currrent; Haldex
carboncow
Post by carboncow »
Thanks JRL, always quick to answer!
I was unsure of the switch from VC to hydraulic as I try to help a friend buy a XC.
I"m pretty sure from other threads that Volvo picked up the Gen 3 and Gen 4 at some point, just not sure which years for sure!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
jimmy57
Been thanked: 320 times
Post by jimmy57 »
2002 haldex in S60 only. 2003 for the rest.
VC is completely different and rear diff nor VC is interchangeable from 2000 down and 2001-2002.
Haldex has some significant differences through its run. Newest version that started in 2009 (maybe 2008.5 for P3) no longer has mechanical pump, uses total electric pump for clutch apply.
Two versions of angle gear. Diagonal case sealed with liquid sealants and the "box" case with o ring sealed removable pinion and side covers. In other words, "leave well enough alone" is not a term describing AWD hardware on Volvos.
This is a macro look at this, there are more running changes than listed affecting interchangeability of pieces.
