Hey everybody!
I am having a long-standing problem with the power door locks on my 1999 S70 GLT for the past 3 years, both with use of the door switch and the keyfob.
ONLY IN WARM/HOT WEATHER the power door locks, especially the driver's, incompletely lock or unlock. The locking mechanism motor can be heard but they seem "weak" and usually don't fully lock or unlock the door.
I've checked the terminal connections on the locks; the car's battery is new and strong without any other electrical problems in the car. I've lubricated the lock mechanism without any change in performance.
POWER DOOR LOCKS WORK NORMALLY IN COOLER WEATHER including wintertime; I've never had a problem with manually locking/unlocking the doors.
Any ideas? Thanks in advance-
KeenanMD
S70 Power Door Lock Problems
VolvoTurbo850
- Year and Model: 1994 850 (T5)
Move to a place where there is only cold weather
? Sorry had to say it, forgive me!
Is this only when you use the keyfob? Manually with key? Or both?
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
JRL
- Year and Model: Several
- Been thanked: 16 times
You need a new lock/actuator assy (as many that are bad)
Common failure
You can also buy used assys.
Common failure
Thanks for the replies-
Doors always lock/unlock manually; during warm/hot weather the power mechanisms don't work with either the keyfob or the armrest lock switch.
The power windows always work fine suggesting it is not a grounding problem.
I understand the actuator assembly is a common failure but why would it be variable with change in temperature?
Thanks for any other ideas!
KeenanMD
KeenanMD
turbozutek
- Year and Model: 1995 850 GLE
If the locks don't look likely (or even do this before checking the locks as it's the work of just a few minutes):
Wait till it's hot and problem is apparent. Remove central locking controller module from CEM; throw it in fridge.
20 mins later, sling it back into the car and try locking it. It if helps, suspect dry joints on the unit PCB or burnt contacts on the relay. One of the failure modes of a dry joint is current limitation - which sounds like your 'low power' door locks.
I had a similar problem on a Volvo 480 Turbo a few years ago (of course it only showed up after I'd installed a remote alarm, causing me to spend hours double checking work!).
What do you mean by a "dry joint"? Is there a way to fix this or does the module need to be replaced if it's bad?turbozutek wrote:If the locks don't look likely (or even do this before checking the locks as it's the work of just a few minutes):
- Year and Model: Many Volvos
- Been thanked: 76 times
The term "dry joint" is common parlance for a broken or faulty solder joint. They typically get intermittent or temperature sensitive as they fail.
- 1491 Views
Last post by joevar
- 1640 Views
Last post by Clemens
- 7521 Views
Last post by precopster
- 1001 Views
Last post by Vova585
- 2604 Views
Last post by erez321
