On the block itself there are two holes where the holes of the oil cooler line up. I had oil coming out of all 4 of these holes (block and oil cooler), this correct?
Last, I want to see if I have a Functioning oil cooler..What is a test I can use to see if it is working properly?
Thank you for your help.
Hose A Black Hose, Hose B Piping
Oil Cooler oil from both ends.
The piping on the top has Coolant in oil mixture and connects to hose A black hose.
