Stinky interior....an experiment
xallenx
Year and Model:
Post by xallenx »
So, we have been noticing a foul smell coming from inside the xc 90 after a rainy day or after washing the car. So, I went and did a little experiment this morning and washed the car without wetting the sunroof to see if the smell would still be there. Waited a couple of minutes and opened the car door...the foul smell was still there. So, my question is, where else could water be leaking into the car creating the foul smell except for the sunroof and roof area? I eliminated that part since I kept it dry but still gets the foul smell. It really is very stinky!
95 850 NA 279K on 1st motor (78K on the 2nd)
06 xc90 FW 2.5T 86K+
Volvos rock3
Year and Model: v70xc, 2002
Post by Volvos rock3 »
Try to run some bleach through the sunroof drains and spray some bleach water through the heat/ac inlet vents (in the cowl area at the bottom of the widshield) with it on. Just be careful with it and hose off any that gets on the paint. Use it sparingly.
1996 850 GLT sdn (deceased)
2002 V70XC 118k
2009 S80 3.2 37k
1998 Chevrolet K1500 84k
1965 Pontiac Lemans convt
2009 Chevrolet Tahoe PPV 2x (work)
volvodoc
Year and Model: 01s60
Post by volvodoc »
replace your cabin filter and return to your dealer to have the afterblow funtion turned on this will run the cabin blower aprox twenty min after car is shut down and will dry off the evap to prevent mold build up also pull the wipers and cowell and ck for plugged drains as well as the cover for the cem on drivers side
007
Year and Model: XC90 0406, 2012 C70
Post by 007 »
Hi, I just came back home, and noticed the passenger rubber floor mat was wet. I dried it with a towel, then I took it out the car and all the upholstery of that section is wet as a sponge!. Today was a rainy day and I passed through some small water puddles...
If you know where can I check to find the place where the leak is I will appreciate if you can tell me...
Thanks.
ChaddGostas
Year and Model: 1996 850 glt
Post by ChaddGostas »
ok, if it is the same setup as an 850, your water is leaking through the hole that your cabin air filter sets up on. Try taking off the cover under the hood, maybe have to remove the wiper arms. then take it off. on the left side, <mine is> there is a hole that the air comes into, and it was leaking down that hole and through the blower motor fan, down the trim panel under the dash and on the carpet. <stunk badly> I ended up taking some body caulk from a parts store and running it along the plastic trim that attaches to the window and another piece that attached to the cover for the air intake. I re-adjusted the foam rubber trim pieces around the two and it almost eliminated the problem.
Check it with the recirculate air button on. there is a trap door that closes and won't allow water to run so quickly into it or at all. pour a bucket of water down the windshield on the passenger side, a gallon or so, and see if it is running down the right side near where your right foot would sit if you were stretched out in front. :)
