My 850 T5 0-60 (and beyond) runs yesterday
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2658 times
Been thanked: 1248 times
Post by matthew1 »
It's hard to tell what the elapsed time is because my camera was shaking. Looking at them with a stopwatch, I'd say 7.5 seconds for the both.
Method: brake + accelerator, then release brake (not parking brake!)
Transmission Setting: Econ, then Sport
This was a lonely, deserted road. Do not attempt. Closed course. Professional driver.
Run #1
Transmission mode: Econ
Run #2
Transmission mode: Sport
I'd just done Mobil 1 10-30 oil and Mann filter change, cleaned my K&N air filter and felt like I needed some bugs in my teeth.
My 850 has no chip or exhaust, but does have a cold air intake (with the red funnel since removed -- it proved to just get in the way).
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
The light on the dashboard is windshield washer fluid low warning.
Also -> Amazon link
taxidad
Year and Model: V70 XC 1999
Post by taxidad »
You might need to top it up to wipe the bugs off your windshield ;-) Very smooth!
peacock
Year and Model: S70 T5 SE 1998
Post by peacock »
i cant stand to have that light come on more then twice. i instantly have to fill it.
1998 S70 T5 SE 214,001
1999 v70R 126,000
Red-Arrow
Year and Model: 850 T5 1995
Post by Red-Arrow »
Your T5 is running like I would expect from a well keep example. It would be nice to get 0-60 in the sub 6 range as that feels fast.
Life would be enjoyable if it wasn't so painful to live.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Even with the brake-clutching, I'm glad to see yours picks up about as slowly as mine does til 25-30 mph.
After that, it's like WARP SPEED!!!
I feel like mine has lost a bit of pep it had back when it had 120,000 miles on it, but it's still pretty freaking quick.
'98 S70 T5
2016 Chevy Cruze Premier
matthew1
Site Admin
Post by matthew1 »
I found a Seafoam-like product at Checker/O'Reilly and have been using it to clean out intake/combustion/injectors just like Seafoam administered through the vacuum tree. More on that within 48 hours, I promise. So that helps.
The K&N helps, and you're entirely free to disagree with me on that, it being one of the DO / DON'T conflicts we have from time to time (oil types, fuel additives, mpg, etc.).
And the cold air intake helps. Same as above, disagree if you care to :-D. For some reason, she came from the factory with an R front spoiler, so that might help at higher speeds with directing wind efficiently.
jblackburn wrote:Even with the brake-clutching, I'm glad to see yours picks up about as slowly as mine does til 25-30 mph.
Justin, I don't think we'll ever agree more on a facet of our Gen One FWD turbo Volvos. Off the line is dogfood. But beware the stock 1975-2005-ish pony car* or Civic Si (just examples) that challenges us at say 40mph. When my 850 kicks down to first, the turbo spools up quickly and halfway through second my neck's getting strained. I love it.
Red-Arrow wrote:Your T5 is running like I would expect from a well keep example. It would be nice to get 0-60 in the sub 6 range as that feels fast.
That would be nice. Chip and exhaust, chip and exhaust. Twelve hundred dollars, give or take. That's only $800 per second (less) to 60mph. ;-) In the world of serious or semi-serious street racing though, that's peanuts, as well all know. "Speed costs money. How fast do you want to go?" -- ancient Chinese proverb.
Unfortunately, Arrow, my 850 doesn't look as good as she runs. Too many apartment parking spaces, if I had to blame one thing. People are vindictive, uncaring animals sometimes. Someone twisted off my headlight wiper and kicked/scuffed the rear door with dirty shoes (no dent, but deep abrasions in the clearcoat) 3 years ago. Then there are the various chips and tiny dents here and there. And the rear spoiler's shine is gone. It's flat black now from sun bleaching (I'm guessing).
* for those outside North America or those unfamiliar with the term: "Pony car is an American class of automobile launched and inspired by the Ford Mustang in 1964.[1][2] The term describes an affordable, compact, highly styled car with a sporty or performance-oriented image."
Also -> Amazon link
jimmy57
Been thanked: 320 times
Post by jimmy57 »
If you really want that 25-30 fixed you need to defeat the low boost in low gears. I'll have to dig around but the wire that goes from TCM to ECM that is used to request no TCV operation which gives the default low wastegate pressure setting can be interrupted with a dash switch. You do not want this function defeated all the time as it makes for WAY too easy wheel spin.
Not applicable to any after 1998 model year as the intro of the CAN computer linkage did away with all the individual wire fun you could have.
matthew1
Site Admin
Post by matthew1 »
jimmy57 wrote:If you really want that 25-30 fixed you need to defeat the low boost in low gears. I'll have to dig around but the wire that goes from TCM to ECM that is used to request no TCV operation which gives the default low wastegate pressure setting can be interrupted with a dash switch.
Uh, Jimmy, if you can dig up how to do this you'll have a 3-day Volvo 850 owner festival honoring you in front of your house one day. I'll organize it.
Also -> Amazon link
jblackburn
Not bad for an old lady. :wink:
I was just curious and had an open road after leaving work yesterday. That's like 5 sec from 20-60 and looks like yours takes 2.5 from 0-20. Don't really have anywhere I can do an actual 0-60 test.
Interesting note, Matt - the shift point on my S70's first gear is just a teeny bit higher (300 rpm or so) than your 850's. This was in E mode; I swear I've seen it touch 6 in 1st gear.
'98 S70 T5
