89 240 wagon
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
This topic is in the MVS Volvo Repair Database » 2004-2007 Volvos with This Feature are Going Up in Value
styles
Year and Model:
89 240 wagon
Post by styles »
:roll: While driving my 240, lost power and stoped so I parked it for a couple of days replaced the battery and it would not start, just turn and turn. Checked the distributor which was cracked, replaced it still same results. Changed rotor, pluges and wries, checked all fuses and changed relays (fuel pump), still same results. I do have spark to pluges and they are wet, but will not start, just turns and turns.
Help
Volvord
Year and Model:
Post by Volvord »
For an engine to run it requires fuel and spark ... at the right time. Your post indicates that you are getting fuel and spark, when was the last time you changed your timing belt? could have skipped a few teeth. But there are many things that would contribute to these symptoms, work through a logical diagnosis, just replacing parts gets very expensive.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
