Windshield wiper skipping
jimmyboy
Year and Model: 1998 S70
Post by jimmyboy »
Hey all,
I've noticed recently that when I leave my wipers on for a while, the right one will begin to "skip" a bit - sort of like old wiper blades do, but it's the arm. It kind of jerks as it's going down, and it's actually really annoying to me.
The wiper blades are fine - the arm just jerks as it comes down. If I flip it to high speed and then back again, sometimes it will stop and sometimes it won't.
Is the motor dead or is there any way to fix it?
As always, thanks!
Gentleman Mac
Year and Model: 850 1995
Post by Gentleman Mac »
Have you tried tightening the nut to make sure it's not coming loose? I had one do that in a storm once on the driver's side; had to pull over until it stopped raining.
1995 854 167k
1998 v70 glt 166k
jimmyboy
Post by jimmyboy »
Yeah, the nut is tight.
My wipers died entirely on my old 740 in a torrential downpour. :D
Any other ideas? Salvage motor perhaps?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Jimmy,
Try this fix:
https://www.matthewsvolvosite.com/forums ... =1&t=18502
Mine has been doing exactly what yours has as well.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Or just try bending the arm a bit for a tighter contact to the windshield
Not too much just a little
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Skipping as in lifting off the glass or shuddering in one direction?
If the problem is shuddering in one direction:
Wiper arms sometimes get twisted and the wiper arm end is not square with windshield surface. This makes the wiper have an angle to glass and the wiper blade can't flip to the side when it reverses directions. Stop wipers in mid sweep by turning off key when wipers are on. Pick up wiper arm and set it back down gently and look and see if the wiper sit straight up on glass or does it lean to one side or the other. Adjust with a small adjustable wrench closed down on the arm to twist it to where wiper stands squarely on glass.
