Troubleshooting Guide or Tutorial for 1988 Jetronic?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
cslayman
Year and Model: 740 Turbo Wagon 1988
Post by cslayman »
Hi,
I'm looking for a good guide or tutorial on troubleshooting the Jetronic system on my 1988 740 Turbo Wagon. I had an earlier post asking for leads on services that test the AFM and ECU out of the car, but no replies. Any links?
Thanks,
Charlie Slayman
1988 Turbo Wagon
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
This is the only trouble shooter I have for that system. It is from a Volvo publication and does use some equipment not normally owned by the DIY mechanic but the majority is doable.
740 1988 turbo trouble shooter Part 1.pdf
(1.35 MiB) Downloaded 229 times
740 1988 turbo trouble shooter Part 2.pdf
(1.14 MiB) Downloaded 203 times
740 1988 turbo trouble shooter Part 3.pdf
(991.34 KiB) Downloaded 1555 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
cslayman
Post by cslayman »
Bill,
Wow! That's exactly what I was looking for! It shows all the steps and tests to run. Most of them only require a volt or ohmmeter.
Thanks,
Charlie
1988 740 Turbo Wagon, manual
billofdurham
We aim to please.
Bill.
Previously:
cslayman
Post by cslayman »
Hi,
My 1988 740 Turbo Wagon is not putting out any power at low rpm under load (2000-3000 rpm climbing up a hill). The engine has absolutely no power. There is boost showing on the gauge. It feels like spark is way off or mixture is lean under these conditions. There is no pinging or obvious misfire. Just no torque. Is there a mechanism that is supposed to richen the fuel mixture under boost?
The engine idles fine. Spark is timed correctly and fuel mixture is good with oxygen sensor operation OK. And at high rpm (>3000rpm on the freeway), the motor runs fine and puts out plenty of power.
Thanks,
Charlie
