Greetings Everyone,
After much research and subsequent frustration, I am still not sure what viscosity of manual transmission fluid/gear lube to use (94 850 n/a 5 speed). Haynes and the owner's manual suggests Volvo synthetic transaxle fluid and Redline suggested 70W80, however, the lowest viscosity I can find in any local store is 75W90. Any suggestions?
Thanks in advance
Manual Transmission Fluid
- Year and Model: Many Volvos
- Been thanked: 75 times
Many say the Redline works well. The stupid expensive Volvo stuff will always work just fine.
I tried Royal Purple 75W90 which claimed it was GL4 compatible and the shifting is notchy until things come up to temperature. It turns out it is really GL5 and it is just too slick to let the synchros work correctly. On the "to do list" is to drain out the Royal Purple and replace it with the Volvo branded stuff.
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
Volvo owners on another board researched Volvo's manual gearbox oil, and found it to be equivalent to 5W30 Mobil1 synthetic engine oil. Based on that research, I've used the 5w30 synthetic in both my Volvos, and have had no issues whatsoever.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
Thanks, Lee and Renns. I will go ahead and try a flush and refill with 5W30 for now and see how it goes; I think the transaxle/clutch may be in need of more major service in the next 6 months or so; we'll see how it goes. Thanks guys
zanzabar
- Year and Model: '07 V70, '84 245
- Been thanked: 4 times
Redline MTL works great for me. It's a 75w/80w, but apparently closer to a 70/85. I tried MT90, it was too thick.
Some info:
http://www.stealth316.com/2-mtl-tech.htm
Some info:
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
