850 surge/lag under load
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: 850 surge/lag under load
Post by jblackburn »
Tackling car problems with a sense of humor. I like your style! :wink:
There are two methods to go about the flex pipe - have an exhaust shop weld a similar one in place, or replace the entire exhaust manifold with an aftermarket one (OBX, for instance).
'98 S70 T5
2016 Chevy Cruze Premier
Fish stick88
Year and Model: 1994 - 850 Sedan
Post by Fish stick88 »
Im having a similar problem, which i think is from drag on the SERP belt. I notice it when i turn on my headlights, run the AC compressor (Especially) I am also having very hard starts about 4-6 seconds, Typically, I can start up on first turn. the weather is getting a bit chilly here..
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
shegarty
Has thanked: 12 times
Been thanked: 8 times
Post by shegarty »
looks like a good discussion going on here - on the topic of the MAF in may case, it is a replacement part from the previous owner - i am concerned now that it might not be the correct part number as i have read that they are quite picky - is there any way (other than calling the extremely unhelpful local dealer) of findind the correct part number for my particular car???
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
jblackburn
93-94's apparently look like this and don't come in the whole tube assembly:
http://www.fcpgroton.com/product-exec/p ... 28Bosch%29
Part numbers: 1366220, 0280217002
All you should really be concerned with - does it say Bosch!?
'98 S70 T5
shegarty
Post by shegarty »
some conflicting info from FCP - your reference quotes part no: 1366220, 0280217002 from FCP Groton but FCP Euro quotes part no.: 1275749, 0280217107 , W0133-1600936 - why is there a difference? is it simply the housing which comes with the FCP Euro part?
jblackburn
Oh, you're right - I didn't see in your signature that you have a 94 turbo - just saw '94' at the right.
The one I put up is for a 93-94 non-turbo. Ignore that.
'98 S70 T5
shegarty
Post by shegarty »
makes sense - will try one from the wreckers before thinking about ordering a new part - things are much better now with all of the repairs and only noticeable when cold under load - will update ...
Dot Heton
Year and Model: 1994 850
Post by Dot Heton »
My 94 turbo has the same thing going on. I was thinking that the fuel injection was hunting for the correct mixture, leading me to think it was an O2 senser.
shegarty
Post by shegarty »
while doing some unrelated work (oil change and drain and refilll tranny) on the weekend i tried disconnecting the MAF again and driving uphill under load (when problem is most noticeable) - it would appear that the demon has yet to be vanquished - surge is still evident and worst at around 2500 rpm
car idles fine even when cold with none of the surging that one would expect if the IAC was bad - IAC has disctinctive hum/buzzing but from what i have read this is normal and should not affect performance
any ideas on what else i can look at????
jblackburn
IAC valve shouldn't cause any of that.
When's the last time you changed plugs? When my gap was off, I could feel the car stumbling around, but it was at a higher RPM.
O2 sensor could still be a candidate for surging behavior.
'98 S70 T5
