Hey all,
I own a 93 850 and I like it for the most part. One question I do have is, how do you read/clear the SRS codes. Ifound a site that says the following:
"A. To read faults, refer to the OBD diagnostic output boxes on the front of the driver's side strut tower. You will find two, labelled "A" and "B".
Remove the selector lead from the side of "A" and insert it into terminal 5 of output box "B".
Turn the ignition "on" to key position II.
Wait about ten seconds.
Press the button on box "B". Keep it pressed for about 1 second.
Read off the LED flashes. Codes have three digits: A-B-C. If code 1-1-1 is read, there are no stored fault codes. If a code other than 1-1-1 is obtained, write it down and press the button again to see if there are more. When the first code recurs, all codes have been read. If you can't obtain any flashing light, see No Codes."
I checked mines and there is no button on output box B. Do I just use the one on Output box A? Anything would help. Thanks!!
New Member - Question
