exhaust leak
jtwerp
Year and Model: V70 Wagon
exhaust leak
Post by jtwerp »
would an exhaust leak cause the CEL to light up?
Dave Swann
Year and Model: v70 2001
Post by Dave Swann »
Yes, it would. Look for a leak upstream of the O2 sensor.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
It can, it depends on where it is leaking. In front of the catalytic converter yes, behind the catalytic converter, usually not.
Have you had the codes read?
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Definitely have the codes read. It may be something completely unrelated.
jtwerp
Post by jtwerp »
got codes from car,
A2: 436 and 435 (slow response from O2 sensors)
A3: 424 and 142 (the cyclops brake light is out)
B3: 122 not sure about this one????
jtwerp
Post by jtwerp »
sorry, forgot to mention the leak is the pipe that comes out of the catalytic converter, if i push up on the pipe the leak stops but comes back when released
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Post by jblackburn »
Post up a picture if you can. If you need help, shoot me an email with the picture and I'll attach it for you.
You can probably fix this with either an exhaust clamp or by having it welded at a shop.
'98 S70 T5
2016 Chevy Cruze Premier
Choguy03
Year and Model: S40, 2000
Post by Choguy03 »
I agree. I'm guessing it it from the flex pipe coming from the rear of the cat.
Been thanked: 476 times
Post by cn90 »
Classic problems:
1. REAR of cat where it meets the Front of Muffler: have a muffler shop weld it, about $50-60.
2. REAR of Exhaust Manifold is the Flex Pipe where it meets the Front of the Cat: for this search forum for:
- OBX (thread by Ozark Lee)
- Volvo OEM Exhaust Manifold, I posted a DIY recently, search for it.
Has thanked: 294 times
Been thanked: 767 times
Since the OP just posted that the leak is right behind the cat, you are both probably correct ;)
OP: here is an example from a couple days ago, where someone fixed this problem
https://www.matthewsvolvosite.com/forums ... 6&p=211457
EDIT: and to answer your original question: NO, an exhaust leak back there will not cause a CEL to light up.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
