The ECC itself turns off with the key but the blower fuse is always on. Most of the times when the power stage shorts out the blower continues to run even with the key off.
Something you can do that won't cost you anything and help with the diagnosis is to pop the ECC control head out of the dash and look for apparent damage. The ECC units have a tenancy to blow up fairly frequently but they normally leave trace evidence in the form a a blown up capacitor, a burned spot on the circuit board, and a big black smudge mark on the top of the inside of the case.
The way I get the control head out is to pop the radio out, you really don't need to remove the wires but if you do make sure you have the radio code, and then reach behind and then pop the controller out by reaching in from behind out pushing it out of the dash. It will resist a bit a first then then release.
Once it is out take off the upper housing and look for damage.
The more information that we have the more we can look like geniuses.
