Ofc it has some flaws, taillights super oxidized, tranny fluid/oil black, intake hose had taped over holes in it that had him spuddering on the drive home, maitnance records show no love since 30k, im at ~130k currently.
Anywho, the thing ran strong after replacing the intake hose and maf, so I went to replacing the other parts, fuel filter, plugs wires, heres when my problem started. I replaced the fuel filter and plugs/wires and went to fire it up, but no dice, engine turns over, but nothing happens. I figured I may have had the plug wires plugged wrong and the previous owner just recently replaced the distributor cap/rotor so I figured id start there. I set the motor to TDC by hand and removed the cap and inspected the rotor, everything was where it should have been so I plugged everything up and tried again, same thing, engine tries to start, rotates but nothin.
Something odd happened while I was trying to start it after setting TDC, there was a pop and I saw smoke coming from my cone filter, I thought maybe the maf popped? so I took off the filter/maf and the smoke was coming from inside the intake, after blowing some out I opened the TB by hand and saw more smoke coming from inside the mani O.o it didnt smell real strong and afterwords when I tried to start it again it went back to turning over, this time no pops or smoke... not too sure what happened there.
Any ideas as to whats goin on? I have no cel either...
