Hood Struts S90
VolvoMaven
- Year and Model: S90 1998
Hood Struts S90
This morning when I tried to open the hood it was very stiff. After trying several gentle up and down actions I was finally able to open the hood to normal position. I have heard of these failing to keep hood in open position, but being very difficult to open is a new one on me. Anyway haved ordered new struts to see if that remedies the problem. Hood is not binding on the wipers or anywhere else that I can determine. Anyone else have had this issue?
Well, if there is a leak, then there would be a build up of moisture and rust. Just a worn out strut. Putting some lube on the chrome part should help prevent it from rusting in the future.
Sent from my BlackBerry 9810 using Tapatalk
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
You may also want to lube your hinges. The crome part of the struts can be wiped with a rag with WD-40 on it.
