Heating fans not working flashing A/C light, help its cold!!
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
olliboat
Year and Model: 1990
Post by olliboat »
have a H-reg 1991 960 2.3lpt. Fans don't work (heating or A/C), when turned on the A/c lights begin to flash. fans use to work but mainly on full power, Any thoughts? i can't find anything on this
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I'm moving this post to the RWD section where it will get more attention.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
If the vehicle is fitted with Electronic Climate Control (ECC), which I suspect it will be, the flashing lights are telling you that fault codes are stored in the control unit. You can read the fault codes yourself by following the information in the attached:
960 AC DTCs 2.pdf
(332.3 KiB) Downloaded 331 times
The light that you place near the sunlight sensor should not be fluorescent.
Let us know if you find any fault codes.
By the way this site is based in the US and "H Reg" means nothing to the US members. Just use the year of the vehicle.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
