check engine-no throttle
frankjones48
- Year and Model: s80 2000
2000 s80 has check engine/emissions service message. aux fan runs on also. no throttle - won't go. trunk won't open with inside button - have to use key. Believe car is being immobilized somehow. All advice or answers appreciated.
JDS60R
- Been thanked: 3 times
Welcome to Matthew's Volvo site !!!
What have you checked so far? Please share the error codes the vehicle has so others can give you advice.
Its kind of a rule here that you must do the initial legwork of getting the codes and sharing what you have checked so far.
Most local part stores check the codes for free so they are easy to get if you do not yet own a code reader.
Post that info and I am sure many will help you.
Best Wishes and success,
John
John
Retired
frankjones48
thanks for the response. don't own a code reader and car is immobilized so can't get anywhere. need to get it rolling. guess i will try to erase codes and see what happens on start-up.
frank
frank
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
If the car starts but wont move, you likely have a linkage problem. Does it start? If it does start, can you rev the engine? If the motor does rev, if you shift the shifter, can you feel it go into gear? Remember we are not there and have no idea what is going on, paint a good picture.
frankjones48
s80 is drive by wire so - no mech. linkage. auto starts and will go into gear but, would not rev. disconneted battery and shorted batt cables. started and driven until stopped when the symptoms re-appeared. last time it wouldn't go it turned out to be the turbo inlet hose was disconnected. hoping for an easy (duh) solution.
frank
frank
- 1034 Views
- 2104 Views
Last post by chris11211
