1998 v70 xc - Automatic trans - button on shifter sticking
This topic is in the MVS Volvo Repair Database » Project: Sticky Automatic Shifter? Here's Your Cheap Fix.
shermy
Year and Model: 1998 volvo v70xc
Post by shermy »
does anyone have an Volvo service manual on dvd for sale? 1998 v70xc
AdlerV70
Year and Model: 2000 V70 XC
Post by AdlerV70 »
How do you remove the shifter knob in step 1? Last thing I want to do is break it. I see that the side tabs hold the leather surround up. I got that down, but I don't see what holds the knob onto the shaft and it's pretty snug.
Why does accountability keep hitting a glass ceiling?
AdlerV70
Post by AdlerV70 »
Nevermind. Just pull straight up real hard and look away so you don't fatten your own lip when it lets go!
KlubMarcus
Year and Model: V70 XC, 1998
Post by KlubMarcus »
AdlerV70 wrote:Nevermind. Just pull straight up real hard and look away so you don't fatten your own lip when it lets go!
Here are some additional pictures to supplement existing replies. The iPd kit comes with color instructions and a spring. 8)
Pull up with two hands hard! It comes off since there are no screws or bolts.
CIMG1740 (448x800).jpg (220.2 KiB) Viewed 3330 times
Broken bottom of the shift knob button.
CIMG1741 (448x800).jpg (188.42 KiB) Viewed 3330 times
Stick the screwdriver straight in to release.
CIMG1742 (448x800).jpg (102.24 KiB) Viewed 3330 times
New shift knob button on left, broken on right.
CIMG1748 (800x448).jpg (124.49 KiB) Viewed 3330 times
It does reattach with a palm smack!
CIMG1752 (448x800).jpg (139.84 KiB) Viewed 3330 times
Use a small screwdriver to get the leather boot back in place.
CIMG1753 (800x448).jpg (232.76 KiB) Viewed 3330 times
:o The beater just won't die! So we're clawing our way back to Stage 0.
Ben850
Been thanked: 7 times
Post by Ben850 »
Thanks for the extra phohos. Today I finally got around to making one fully functional, and aesthetically pleasing shifter out of three.
My original black one on the left, from which I took the black button and installed it in the one on the right. I just put the grey piece back into the old one, as to not loose the pieces. (you never kknow)
I sprayed some white lithium grease in there to keep things moving.
The part that was originally confusing me, was that you have to pry the button out from the top to simply slide it up an out.
Thanks again for the explanations, I had to dig up this thread again to remember.
One out of three aint bad.
shift knob fix.jpg (58.79 KiB) Viewed 1730 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Yellowstone Savage
Year and Model: 850, 1997
Post by Yellowstone Savage »
Great step by step and pics ... wasn't sure where that spring went. BTW, I placed a block of wood on top of the console and then used a screwdriver to pry the top off with a tap of my hammer. (Wish I'd read this before I spent an hour removing the entire shifter assembly out of junker at the u-pull-it.)
jigejohnson
Year and Model: 1998 V70R
Post by jigejohnson »
So my button is stuck out (won't depress), therefore not allowing me to take the car out of park. My shift override button doesn't work to get the car into neutral either. How do I get the shifter off to replace the button if I can't get it into neutral? I pulled up on it and it won't budge. . . I assume it needs to be in neutral to get it off. Can I switch the car into neutral from under the hood? Please help! (1998 Volvo V70R AWD Turbo)
Ben850
Post by Ben850 »
Pull very hard using both hands and wiggle it left and right. Keep your face away from above your hands or you may knock yourself out.
