97 960 with a misfire issue
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
mechanye
Year and Model: 960 1997
Post by mechanye »
1997 960 with 150,000 miles. It developed a rough idle that throws a p0302 code. First I have swapped coils around that had resulted in not causeing a diferrent cyclinder to misfire (coil pack is good). Second, I swapped the ignition coils around which resulted in a p0305 code and not the p0302 code (lead to my assumption that the ignition module was bad that controls cyclinders 2,4,6). I replaced the ignition module. I still get the p0302 code and when swapped with the other one, i get the p0305 code. Now what the chances that the new module is bad and causes the same cyclinder to misfire? Any suggestions before I send this thing to the scrap yard?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Make sure the wires that go in the back of the coil pack connectors are in good. Mine was backing out and causing missfires.
mechanye
Post by mechanye »
thanks for your reply. I have checked that issue. The wire harness isn't in the best of shape but both banks run fine off the ignition module that controlled the odd number cyclinders. the ignition module that contolled the even numbered cyclinders was causing number two cylinder to misfire and when swapping it to the odd numbered ones it caused number 5 cyclinder to misfire. replaced the ignition module but am still having the same results.
mechanye
Post by mechanye »
No more worries---- I sent her to the scrap
yard!!!!
