Everyone,
I have checked all lights and they are on and working properly. My warning is still on, I have read other comments in other websites and some have stated that it could be a relay. Is the relay solution a possible one?
Bulb Failure Position Light Topic is solved
many thanks this was doing my head in I
had a faulty interior tailgate light,
replaced but was still on,
BUT then notice after reading this post that the double
filament tail/brake light was blown
problem resolved
Hurrah
problem resolved
Hurrah
I had something similar happen on one of the tail lights on my car, when I wen't to get the "burnt" bulb out, I noticed the filament was still intact, but the "positive" side of the connection was worn down at an angle such that the copper plate to which it connect couldn't make contact anymore; a little work with a file later and connection is all good and hasn't complained in a bit over a year.
2001 V70 T5 - 150k miles and going strong
JsNextVolvo
- Year and Model: XC70 2004
Had the same message appear yesterday on my '04 XC70 and I thoroughly searched/inspected the 20+ bulbs (thanks for the description of which bulbs were included) around the body and could not find one not working. Today, having done nothing (except drive a few hundred km) the message does not appear. Will keep in mind others' advice for next time that it may likely be a poor connection that requires a gentle bump or contact(s) that needs cleaning.
RedGeminiPA
- Year and Model: 2005 S80 2.5T AWD
Excellent thread. I'll be keeping an eye on mine as well, since I've been getting this message the past couple of days.
2005 S80 2.5T AWD
Capt Richie
- Year and Model: 2004 V70
With all due respect, most bulb failures are due to a burnt out filament, not faulty contact. Pounding on your Volvo may cause the dangling filament to flail around and make a temporary reconnection but it usually won't last. Just sayin'.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Agree Capt. On my '04 the bulb had an internal short- I'd smack the back of the car and it would work for a little while. I kept thinking it was the socket but when I finally replaced the bulb all the problems went away
bob ogletree
- Year and Model: 2007 xc90
This really works; I just went out and hit the rear outside light area and the light came on and the messages disappeared. Super advice. Thanks
- 4907 Views
Last post by Oly850
- 4140 Views
Last post by silentcircuit
- 24715 Views
Last post by JNavas
- 5069 Views
Last post by JRL
- 21 Replies
- 12114 Views
Last post by Georgeandkira
