Rear caliper hang up
KEEman
Year and Model: V70 2003
Post by KEEman »
Just put new ceramic pads on my 2003 V70 and the rear wheels keep getting hot. I've cleaned all the dust off,but that doesnt seem to be helping. Any suggestions?
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
Could be a couple things. As you already indicated, if the caliper is getting hung up, it could be holding the pad against the rotor and causing friction.
It could also be the rotors. The particular hardness, metallurgy of the rotors may not be ideal for ceramic pads.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
KEEman
Post by KEEman »
I'm going to put new calipers on this weekend. I will post an update
Thanks
draser
Year and Model: 2005 S60 2.5T
Post by draser »
Basically you need to make sure the caliper floats on the pins, so you need to clean the pins good and smear some moli grease on. You can tell by looking at the old pads if the cal was stuck. Also clean the pad carrier with wire brush, I use brass, and smear moli grease on the carrier and pad ends - where they engage the carrier.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
