1995 940 T wagon headlights
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
boats
Year and Model: 1995
Post by boats »
I have a 1995 940 T wagon. The headlights do not work in low beam.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Have you checked fuses 19 & 20 and the bulbs/connectors?
If they are OK run a jumper lead from the battery + terminal to the connector on the headlight. Left headlight is a green wire and right is a green/white wire. You only need to touch the connector to see if the bulbs work. If they don't work check the earth (ground) connections which are located at the front of both fenders.
If these check OK you may be looking at a faulty bulb malfunction unit.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
