Cutting out
lyndon
Year and Model: 850 95
Re: Cutting out
Post by lyndon »
Thanks for that i will give it a go.And i will let you know the outcome.
lyndon
Post by lyndon »
Thank you all for helping out with my problems.After changing spark plugs, coil and overhauled the distributor cap and changed the thermostat none seemed to have resolved the problem.So i changed the fuel fillter which seems to have solved the problem fingers crossed all as been well for the last week,so thank you all.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
If the problem returns it could be a bad engine coolant temperature sensor. In that case, change it and the thermostat. Volvo sensor is expensive, but worth it. The wires pull out of the aftermarket sensors after a short time.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
