1) dont do that in N or P. Bad things happen. think trying to pedal backwards on a bike as fast as possible. Not good.
2) how is it in drive? The same?
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
it was in Park when i revved it up, any other car will rev freely throughout the RPM range. In drive its been slugish, although the 4T65E is showing its usual downfall, it doesnt boost/pull like a turbo car should. My other cars are 2 Volvo 850 turbo's and i have been around Turbo engine for over 20 years and this feels like its not receiving spark to a cylinder, almost like a bad coil. I bought this T6 3 months ago and its super clean i must say, and i havnt got around to driving it and really feeling the powerband because of the occasional "limp mode". I really appreciate you guys replying back and i will keep researching more to find out what it is.
PS i do remember when i was checking the plugs, one of the coil boots came off from the coil body, im wondering if its a bad coil. hmmmm
How would i check the coils? i cant remove them one by one while the car is running, because of the turbo plumbing... so.. i wold think i need to read Ohms, which is not my department.. but a rev limiter make sense, and a bad coil makes sense as well... and the only message i got in the lil window in the cluster is SRS... and a Red triangle in between the speedo and RPM gauge.. will look into it.
BTW is there a PDF file for the transmission removal on this forum? i did a search and couldnt find one if there has been previous postings... thanks again guys..
After transmission upgrade, is the fitting of the twin TD04's and 3'' custom exhaust system and etc....
lol, yes its twin turbo, but revamped, i have fabricated a few turbo/twin setups, 300zx, Mazda rx7, grand national, datsuns, and now my lovely T6..custom intake from the front grill and then a custom intercooler setup, and so on .... should be an interesting ride...lol , and in the mean time, pump some more HP's put of my 850 T
