high mileage oil
slimflex2
Year and Model: volvo 850 R 1997
high mileage oil
Post by slimflex2 »
Hey guys need your help.l just changed my oil to high mileage.before l start the car,l check oil level and its in original color but once started up the oil looks white with some bubbles in it but after a minute or two it turns back to its original color.what could b the problem.or is it because it is cold ?thanks
osman
Year and Model: 2002 c70 hardtop
Post by osman »
white with bubbles?
you might have coolant in your oil.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Can you take a picture? It's normal for the oil to be a little agitated when the car is running. I always have a tiny bit of bubbles on mine, but it still looks like oil.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
slimflex2
Post by slimflex2 »
l dont think its the head gasket.my radiator is leaking and its visible. it gets to normal oil color after it warms up with noo bubbles or white color.even before l get it started the oil looks fine.
s70glt novice[Will]
Year and Model: s70 glt 98
Post by s70glt novice[Will] »
look in the coolant tank. If theres oil in there.... theres your problem.
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
slimflex2
Post by slimflex2 »
theres no oil in the coolant. if there should be oil in the coolant what color would that be?black? my coolant looks green.
