leaking radiator.
slimflex2
Year and Model: volvo 850 R 1997
leaking radiator.
Post by slimflex2 »
does anyone know how to fix a leaking radiator?thanks
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
It depends where it's leaking.
If it's just a crack in one of the tanks or neck of the radiator, you can drain it, sand down the area of the crack, and then apply some of the high-strength JB Weld that you can find at an auto parts or home improvement store. Do not use the quick-set - it doesn't hold as well.
'98 S70 T5
2016 Chevy Cruze Premier
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
Your post is rather vague and the information not specific enough to answer your question.
Where exactly is it leaking? Is it leaking at the reservoir? Is a seam leaking? Is a connector leaking? Is there a leak in one of the cooling tubes/fins?
How much is it leaking? Is it leaking a drop an hour or a gallon an hour?
Depending upon the details you provide your answer will vary widely from :
- simple fix - pour in some silver solder powder
- clean and apply Weld like JB described
- replace an o-ring
- remove the radiator, weld the spot
- remove the radiator, replace the gaskets
- remove and replace the radiator
In order to help you, you need to provide more details.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
slimflex2
Post by slimflex2 »
the leak is on the upper side of the radiator on the drivers side.when the coolant is running with the fun running l see smoke on the drivers side of the radiator.the leak is about a drop in two days.not that of a big leak
jblackburn
Try the JB weld approach if you can get to where it's leaking. Drain the level a bit, make sure the area is dry, and then scuff up the plastic a little bit before applying the JB.
You may have to remove the top cover and/or fan shroud to actually reach parts of it.
'98 S70 T5
