Hi Folks,
Now trying to get the timing belt back on my 98 T5. Getting it off from around the harmonic balancer pulley was very difficult, and it took turning the pulley itself to "squeeze" it off. Is the pulley supposed to come off for a timing belt replacement? Other instructions indicate not, but there is no room behind the pulley for the belt to get the belt off and then onto the crank gear.
Thanks for your help,
Danny
1998 S70 T5 Timing Belt Replacement
ddpphx
- Year and Model: 2005 S80
Dan P
88 240DL - almost 200K - dead, but saved my life
98 S70 T5 - 133K - dead - tranny quit
05 S80 - 273K and going strong
04 S80 T6 - 254K and going strong
ddpphx
Thanks. However, I did remove that cover and still cannot get the new belt on as there are parts just behind the HB. Doesn't seem to be the place for a turbo to have extra parts that a non-turbo wouldn't, but nobody else seems to have this problem. Hmm.
Any other thoughts?
Any other thoughts?
Dan P
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
If you have the cover off, then all you have is the little piece of metal sticking out that is always in the way. I pulled my belt tight between my hands angled it onto that metal piece and it seemed to go on pretty easy. doing it loose and trying to force it just didn't work for me. It came off, it will go back on.
Hope this helps.
No extra parts down there on my turbo.
Shane
Hope this helps.
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- Has thanked: 292 times
- Been thanked: 765 times
It will go on, you just have to fiddle with it. Others have the same experience with this you are not alone
I find it is really key to watch how it comes out, then put it back in that way. I know that doesn't help you now but FYI for future jobs ... You start with the belt face vertical and once it is through the crack, the belt can flatten out without too much effort. I sometimes use a screwdriver to push it in that is OK, but do not do anything that would stress out the timing belt. There is a bolt head behind there that sometimes causes problems, that is on all models. Just keep at it.
See this link if you haven't already, maybe it will help
http://volvospeed.com/volvo_repairs_how ... hange.html
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
ddpphx
Thanks for the encouragement to carry on, guys. I got it on. Changed my own water pump. That's a big deal. For *me*.
Dan P
